OBD2 Readers
amledford
GR Michigan
2001 Champaine Coupe
OK, what is a good OBD2 reader to get to reset codes (like the Fuel Trim Tables). The Tech II is expensive, so probably isn't the best for an occasional use. What about the OBDII AutoTap Diagnostic Scanner (I think this is used with a laptop computer), or the Global OBD II AutoScanner CP9135 from Actron?
I put in a new intake and now I'm getting an O2 sensor fault (10-PCM P1416 current). Would this have been affected by the change in intake (K&M dual filter)?
Would resetting the Fuel trim (as suggested by C4C5) be the answer?
I have a 2001 with 24K miles.
The auto-tap is a read only device. It will monitor a lot of the inputs to the computer, but that is all. Most people use it with LS1-Edit. Edit to change settings, auto tap to monitor results.
I have one for an LS1 if you want one cheap.
John
