For a weeks now i had a slowly raising headlight (passenger side). After starting the car, it would slowly go up and after driving for 2 minutes it would go all the way up.
Finally i had some time to check it out. After reading tons of stuff on the troubleshooting of the vacuum system, i performed a few tests, but i am unsure if my finding(s) are correct. If someone could verify my result and conclusion, before i order a part that would really help..
Here goes:
I checked the Vacuum at the manifold: Appears in the 18-20hg range.
The Filter right there is full of crap, so i will order one of those.
I further plugged my camping pump (it's a double pumper with in and out) into that side and pulled vacuum and it appears to start raising the driver side and the passenger side (slowly), so i am assuming the check valve is functioning.
I then checked the relays. First the passenger side and it appears to function (the pin inside goes in and out when vacuum is applied to the control port on the top). Same with the other side.
So i swapped them. Now, the passenger side barely makes it out of the hole for 1 inch and i got a hissing noise. hnoes
I then applied vacuum directly to the actuators. Passenger side: When applied to the front, it barely raises the light. Driver side: Easily comes up.
My assumption is the actuator is toast. Is that correct? Is it worth to take out and see WHAT is wrong? Or should i just order a new one ($90 + S&H)?
I might be able to order/get them here locally, but i havent checked yet.
Or am i missing something, and it's more likely the relay? I honestly dont know if i can take either apart with that ring around them that needs cutting and soldering back on.. :ugh
I should mention that the driver side actuator was replaced 15 years ago and still looks shiny, then passenger side is rusty and appears original, with color coded hoses.
Any advise would be appreciated...
-Stefan
Here goes:
-Stefan
