Help! OIL 1982
jack62
New member
BOSTON
1962 ROADSTER ROMAN RED**2003 CONVERTIBLE TORCH RE
Hi Everyone
My friend just bought a 1982. Does anyone know if 5 quarts 15-40 is correct??
10W-30 should do ya. Anything more will be too thick, especially in winter if you plan on occasionally firing it up.
15-40 is more along the lines of a heavy truck oil, if I recall correctly (which I may not be...:))
My advice is to use what the owner's manual specifies.
I knew that was coming...thanks for not letting me down. It was going to be either you, Hib, or Mikey. :L
Interesting...two threads on the same subject....an oil recomendation for an 82 bought by a friend.
What's listed in an 82s owner's manual is no longer made by the oil industry. Fortunately, virtually all of the engine oil available to consumers, today, is far better than anything suggested in 26-year old owner's information.
If the engine is stock, any 10W30 engine oil API certified SL or SM will be fine.
If the engine has any valve train modifications (such as higher lift cam, higher ratio rockers, increased spring pressure), an engine oil with higher phosphorous content is required. The cheapest way to get that is with a light truck diesel engine oil such as Shell Rotella 10W30 or Chevron Delo 400 LE 10W30. The best way to do that is with a premium synthetic such as Red Line 10W30 and, there are other choices between those two but, whatever choice you make for an engine with valvetrain mods, you need between 1000 and 1200 PPM phosphorous content.
oil
I just couldnt resist. You made it toooooooooooo easy.
Thanks again
Jack
