B
bigvette1
Finished rebuilding the BB and after breakin and maybe 200-300 miles it is using oil. If fact, you can see a haze from both exhausts so it is considerable.
Here are some symptoms or info.
1. There is no oil inside the PCV hose so I am not sucking it out of the valve cover.
2. With the PCV plugged you draw a vacuum from the other valve cover - that seems right.
3. With both the PCV out and the other valve cover opened, cover both valve covers and you have a postive pressure - think that is ok also.
4. Compression is equal on all cylinders.
5. All spark plugs are equally black and have a oil coat.
So this seems to be 3 areas: Intake manifold, valve guides or seals or rings.
Queston - is there a fairly reliable way to determine what the cause of the problem is??
