goingballistic
Just an FYI.
During my dyno test I ran regular Valvoline 10w-40. Between draining the oil out the two piece timing cover
ad and vibrating my oil filter loose, I ended changing the oil for the second day on the dyno.
The guy who owns the shop told me to use Valvoline VV851 Oil for breakin. Apparently this stuff has Zinc in it. From what I have researched so far, the EPA has had many of the additives removed from motor oils, such as zinc and other chemical packages that actually help the engine in these applications, Valvoline is one of the few that still carry zinc. So for break in I ran the VV851, drained it and will run regular 10-40 or 50 for the first 500-600 miles then run another load of the VV851. I plan to run this every other oil change and see if it makes a difference.
Just passing on some info I thought might be of interest, cheers.
http://www.valvoline.com/pages/products/product_detail.asp?Product=94
ad and vibrating my oil filter loose, I ended changing the oil for the second day on the dyno.The guy who owns the shop told me to use Valvoline VV851 Oil for breakin. Apparently this stuff has Zinc in it. From what I have researched so far, the EPA has had many of the additives removed from motor oils, such as zinc and other chemical packages that actually help the engine in these applications, Valvoline is one of the few that still carry zinc. So for break in I ran the VV851, drained it and will run regular 10-40 or 50 for the first 500-600 miles then run another load of the VV851. I plan to run this every other oil change and see if it makes a difference.
