berry1133@bellsouth.net
Hello L81 family. I have a little oil seepage on the front and rear of my right side cylinder head. It appears to be coming from in between the head and the block. I am not getting any oil into the cylinder as the plugs are dry and, all cylinders are holding compression about the same Also, I haven't had to add any oil. My first thought is to check the torque on the head bolts. (what should that be? I have aluminum heads)
What do you guys suggest?
Thanks,
BBerry
Thanks,
BBerry
