oil leaks
dbheff54
New member
Halifax Ma.
1962 327 300hp Roman red
New to me 1962 327 300 hp a couple of oil leaks. Found and fixed one, oil pressure gauge fitting on block not sure where the other is.Like to find a mechanic was referred to a mechanic on Union st in rockland Bobbi Craig can't locate his num any help would great.
Welcome to the CAC
Most common would be the valve covers. You could pressure wash your engine and then it would be easier to see where a leak is coming from.
Tom
Tom
Not valve covers engine is very clean all around I was thinking Oil pan oil filter worst case rear seal car was sitting in a collection for a while gaskets dry out it slowed down a little after two weeks of on and off driving.I have a small window to get this fixed seller will pay.Will probably drive to Rockland and see if mechanic will schedule me in.
The rear main is a common place for these Gen 1 small block chevy engines to leak. Unfortunately, there is not much you can do to prevent it from leaking. Even if you manage to stop it temporarily, it will eventually come back.
oil leak
Gotta get it up in the air and clean everything off ck pan and oil filter can.Was leaking from oil pressure fitting fixed that could still be oil migrating.Time will tell thank you very much for the Info.
