Oil pan and Tranny pan gaskets
iamfine2
Minneapolis
Hi Everyone,
on my 1981, can the oil pan and tranny pan be dropped off the car just on jack stands?
I need to replace the leaky gaskets, but do not want to pull the motor.
Mike
Oil pan removal.
If you remove the idler arm at the frame and put the timing mark at 5 o'clock, looking at it from the front, the oil pan will come off.
The trans pan is easy, remove all the bolts except the 4 corners, then loosen the front bolts, then remove one rear then loosen the other and have your bucket ready! PG.
