Oil Pan Gasket Change
C
Claude Mundy
I need to change the oil pan gasket on my LT4. To do that, I need to remove the engine mounts to get to the front studs on the oil pan.
What's the best way to support the engine? Can I put a jack under the transmission? Will the bellhousing and transmission case support the weight of the weight of the engine? If I rented an engine hoist, where on the engine do I connect the hoist?
motorman
pa
2008 Crystal Red Tint Coat
fel pro pan gasket
use a 1 piece fel pro pan gasket as they are leak proof.
