Bolisk
So a few weeks back I noticed something that has me concerned. When I really get on it. . .after the RPM crosses approx 4,800 the oil preasure drops considerably. WHY?!?!?! It never goes to 0, but it dose start to drop, then once my rpm's drop the psi goes right back up. Could this be the bypass in the filter. . .and would that have any effect on the PSI? Or am i sucking air? Is it possible for all that oil to be pumped up tot the top and not drain down enough to starve the pump?
Some background info that might be helpful.
1) My car is a L46 350/350
2) It is outfitted by the revious owner with a high flow / hight preasure oil pump (idle is 35 psi when oil is warm, normal running is arround 70psi)
3) I was running 10w30 oil when I noticed this behavior.
Next, I have recently change my oil from Mobil 1 10w30 High Milage. . .to Mobil 1 15w50. (the oil pressure drop still happens) The reason why I changed to that oil is because that is the oil that Mobil specificall recommeds for flat tappet lifters (lots of zinc and phos, over 1500 parts per million). My car has LT-1 guts, and is running solid flat tappet mechanical lifters. I was running the high milage because it had 1,000 parts per million zinc. So the next question is, is that weight way to thick? In other words is it safe to run? Next question is, if it is safe to run. . .is it safe to run on that high preasure / volume oil pump, and should i replace the pump back to stock?
