oil pressure at idle
M
muzy67
Just like to know normal operating pressure at idle as well as @ 2000rpm. My pressure reads as low as 13 psi at 600rpm. Oil qty good. No external leakage evident. At cruise, 1800/2000rpm, it reads 45psi. I read my manual for norm. press. @ 2000 and I am on the low side of that range if not out. It is not clear on idle pressure. Maybe my pump is going???
-=Jeff=-
Bartlett, IL. (Chicago Suburb)
1990 ZR-1
My minimum rule of thumb is for every 1000rpm the Oil pressure should be 7psi..
it does sound low at idle though mine is in the 20's at idle (engine warm/hot) and around 45 or higher while accelerating..
I have an analog gauge so it is tougher to pinpoint
WhalePirot
SoCA
1984 White Z-51/ZF6-40/Shinoda body
That pressure may not be low. What is the viscosity of the oil? The synthetics are thinner and supposedly slipperier, er, more slippery, hence the high pressure of yore is not essential. At least, that is from Mobil, in their Mobil One brochure.
BTW, you can edit your message by clicking on the little <edit> link; lower right. With my fingers, I get lots of practice!
Welcome to the best Vette forum/gathering, without cars, anywhere! :w
fixvet
Clever, MO
1998 Two Tone Torch Red& Black Coupe
I run 20W50 Castrol High Mileage oil, w/ engine ol hot/normal temp. at 600-700rpm idle..40lbs, at 75-80mph higway speeds at 1900-2000rpm..65lbs of pressure.
No leaks, no burning oil at 160,000 miles currently.
Have fun,
Fix
Tom73
Round Rock, TX
73 LS4 Coupe - 04 CE Conv
Yours sounds good to me. I don't know the Chevy specs for '86 but way back in '73 the Chevy standard was 40 psi at 2000 rpm.
tom...
M
muzy67
Thanks ya,ll !!! I'll have to check the wt oil when I get home. Hey Fixvet, I have 170,000, of which 166,000 are mine since Mar '90. Its been a great ride and still is. I'll check that high mileage oil out. thanks
vigman
Motor head!!!!
Valencia, CA,USA
My numbers 1988 L-98
Castrol 20-50
130K on engine
Idle ( HOT ) 500-550rpm
20-24psi
Been that way during summer....
2K cruise 45-50psi
Cold Idle 45 psi
FYI
Vig!
cntrhub
North Hollywood, Ca.
Miss my '62 & '80 4- Sp. Vettes
There is an access plug near the oil filter to check oil pressure with an oil pressure gauge..... if you have one. This will give you a real reading of your engine's oil pressure.
Worn crank babbit bearings will show a decrease in oil pressure. Any tolerance readings like the crank bearings or cam bearings will show a loss of hydraulic pressure. This and other resistance type features in an engine (orifice holes) are what determine pressure variables.
M
muzy67
Yea guys, I,m sure my engine is getting worn. I just noticed my pressure drop in the last couple of months. I may have to upgrade to a different forum, no reflection on ya'll if you know what I mean! Thanks for the input.:_rock
Ken
Gone but not forgotten
Hermosa Beach, CA
1987 Z51 Silver Coupe
cntrhub said:
...babbit bearings
Prior to 1940 just about every machine built used Babbitt bearings, and every mechanic was familiar with them. If you ask the average guy under 40 years of age today if he has ever heard of Babbitt you will likely get a blank stare. ;)
_ken :w
FrankM
Derry, NH
Depending on my sending units mood, I get 25lb at idle with pennzoil,quaker state 5w-30
If I use mobil or exxon I get as low as 15lbs red hot idling.
At 1700 rpm ....68mph I get 55 -59 lbs
I've only used 5w-30
original everything!!!
I have changed the sending unit a couple of times because they are not consistent. I have giving up changing them.
Use a mechanical gauge if you want accuracy.
C
c4ever
On the 85; 80K miles
Hot engine: 28-32psi idle 58-62psi cruising.
Running Mobil1
Carlo
