Oil pressure diagnosis in 72 Vette
L88 crazy
home
1972 Blue T top
I got a 1972 corvette t top with a 350 small block. It was rebuilt in the late 70s. I am having oil pressure problems. The oil pressure will be at 70 psi on startup, when warmed up it sits on the first white bar on the gauge. When in gear it drops to 0 psi. Here is when it gets weird. I understand that of it drops to 0 psi the motor will knock correct? Mine doesn't knock, ping, or grind at all any any way! I had the gauge rebuilt but no changes. Was the motor rebuilt incorrectly? SOMEBODY HELP ME OUT OF THIS CONFUSION!!! Great thanks goes out to all who help me out.
Low Oil Pressure
I have the same problem with my 77. After about an hour of driving if I stop at a light in drive the oil pressure drops close to 0. If I put it in Nutral it jumps back to 30psi. Strange
I have a feeling your oil pump has gone bad or is just worn out. I would suggest pulling the pan and first check if the pick-up is still in place. I would still replace the oil pump with a high volume pump.
One other thing to watch for is the oil pressure pulseing like a heart beat when you are at idle. This would tell you that the main bearings are bad.
Good luck.
With both these engines, the first thing to do is check the oil pressure with an alternative, known-good gauge.
If the results are similar, then both engines may have problems with oil pressure.
Not a lot of addtional information was given.
What kind of oil is used? If it's lower than a 10W30, use a higher viscosity oil.
What is the mileage since the last overhaul?
Have either of these engines had any modifications that affect the oiling system?
Without the answers to those questions, it's awfully difficult to diagnose by Internet, however, if the oil pressure is checked with a known-good gauge and is less than 20 psi hot at idle, you could pull the pan and check the oil pump.
Another thing to look for is an internal oil leak--perhaps a front oil galley plug that's fallen out or a leak around the dist. body.
If you drop the pan find the oil pump and pick-up are ok and there are no internal leaks, try replacing the oil pump pressure relief valve (it's in the oil pump bottom plate behind a roll pin) with the "high-performance" spring, GM PN 384891. In an engine with an oiling system that is working right, using SAE30 oil, this usually makes 60-70 psi, hot, oil pressure at mid-range or higher rpms. Generally, the rule is 10 psi hit oil pressure for every 1000 usable rpm. So...if you're engine has an upper usable rpm limit of about 5500 rpm you want at least 50 psi.
Also, on "high-volume" oil pumps. Contarary to what's posted previously in this thread, there are very, very few SBV8s that need high volume pumps. This is especially true of stock or even most modified engines using production blocks. In most cases high-volume pumps do nothing but add parasitic power loss and pump too much oil into the top of the engine. Bottom line: unless you are building a very high rpm race engine (such as for NASCAR or drag racing) don't use them.
