FactoryC3
I want to thank all of you who answered with ideas. Here is the history and a final fix.
Installed a new GM Restoration oil pressure gauge and the new one solved a nagging problem I was having. I was getting varied readings from my factory gauge. At start, it read at about 20psi and after about 3 minutes run time it would jump up to 50-60psi with jerky movements. I tested the circuits and all pointed to the sender as the problem as the gauge passed all of the tests outlined by Willcox Tech Support online. Changed the sender and still the problem was there. Checked ohms output from the sender and actual pressure with a mechanical gauge. All read great. Decided to change out the gauge as the next step, and the work tearing the console and gauge cluster down was well worth it. Fired it up and Problem Solved. Glad I changed the gauge even when it passed the tests. Just want to follow up FYI. While I had the cluster out I changed all of the light bulbs and assorted gaskets.
