slapshot
After buying my 91 Vette, I changed the oil to Mobil 1 10w-30 and K&N filter. Since the change, the oil pressure gauge is reading slightly higher. When the engine was cold yesterday,the pressure actually topped out just under 80. Once it was warmed up, it was slightly higher than it was. Warmed up, it usually is in the middle of the gauge range, with slight flucuations above and below depending on rpm. I checked the oil level with the engine warmed up, and it was still the same, so I'm not burning oil. The oil temp is slightly lower.
I know the cars gauges aren't terribly accurate, but I did see a difference before and after, and wanted to make sure nothing is wrong.
