Z
zenmaster1193
thanks for the help on explaining how to remove the fuel pump, but before i finished the job i was curious as to why the prob started. there is an oil recirc. hole in the pump from the block, right, and my oil pressure was reading very high previous to repairs, causing some leaks from what i believe is the rear main seal, however, i have tried bleeding the lines, replacing oil and oil filter, though none seem to be very good solution, and my pressure is still very high...would that pressure have been able to damage my fuel pump, causing it to expel out of the weep hole? if so, how can i decrease oil pressure, or should i even worry about it, will it cause more damages? (we're talking around 70 on the gauge, even at idle, with some increase during heavy accel.)
matt
matt
