W
WhiteKnight
Trying to decide if I should replace the oil pump while I have the pan off.
I was looking for the source of a squealing noise from the front of the motor last week. Found the AC belt had hit the lower hose and caused a good nick. While replacing the belts I saw the balancer had seperated and was back against the timing cover. Ah ha.. source of noise found - ouch! So I figured since I'm going to replace the balancer and possibly the timing cover I might as well replace the chain and gears, oil pan gaskets, valve cover gaskets, water pump gaskets, timing cover gaskets, radiator hoses and clean up and paint as much as possible on the motor.
So now that the oil pan is off I found lots of plastic chunks in the pickup. Lots of grit too. Not sure where or what the plastic is from does not look like a gear, maybe a bushing from somewhere? It did have a HEI distributor in it when I got it (now a dual points Accel) so I'm not sure if the origional dist had a failure and that is why it was changed. The oil pressure runs around 40-45 at startup and 35 when warm at idle. With load it runs 35-40. I have checked against a secondary test gauge as I did have to repair the gauge when I got the car, and I wanted to verify it was semi accurate.
Anyhow should I just clean out the debris from the pickup or replace the pump, shaft and shaft guide? If I do replace the parts should I get a stock or a high volume pump ? This is a base motor 350 - 270HP with AT that is used on weekends for crusing. I've put maybe 1100 miles on it since October last year and it does get winter use, but only because of the mild weather here in Texas.
One last question.. if I do replace it, should I put the timing chain/gears back on first before pulling the pump?
-thanks
-thanks
