Space Cowboy
- Joined
- Oct 8, 2003
- Messages
- 408
- Location
- Houston Texas
- Corvette
- 1968 Convertible - Candy Apple - 427/475+
This problem in on a '68 350 small block.
I have oil seepage from a intake manifold bolt over the #1 cylinder. The oil is actually settling in a cavity on top of the manifold. Ironically enough, I'm also getting fouled plugs in that cylinder as well. I know that I could have ring problems, but I don't think you usually see oil seeping up from a manifold bolt if that were the case. Could I have a bad manifold gasket in this case?
