S
sumoboy
Finally got it to work....:booty
1. Place transmitter at least 10 feet or more from car.
2. Turn ignition switch to the ON position. (Do not start Engine)
3. Push the TRIP/ODO button on the Driver Information Center (DIC) twice.
4. WITHIN 5 SECONDS, push and hold the FUEL/INFO button on the DIC until the PKE light on the DIC display (center of dash) comes on and stays on.
5. Turn the ignition to the OFF position (one click back from the "run" position ). The PKE light will begin flashing. If you go too far you will be in the "key removal position, the PKE light will not flash, and you will need start over at step 1.
6. Bring one transmitter into range. When the system recognizes the transmitter the PKE light will stay on.
7. To program an optional transmitter, move the newly programmed transmitter out of range (PKE light will start flashing again) and repeat step 6.
8. The transmitters are now programmed to the vehicle.
9. To end programing and return to normal PKE operation, remove the key from the ignition or turn the ignition to ON.
