S
studiog
Having problems with stripped screws when installing my door panels to the fiberglass. What is the best way to deal with this? Also the top edge of the panel doesn't have a tight fit to the door. Is this normal?
critchie said:3. Place a wire alongside the scew in the hole. Screw the screw in with the wire alongside. Sometimes that'll give it enough bite.
critchie said:2. You can try dry wall inserts too. Those plastic things designed to hold screws in dry wall. Sometimes they work.
That is a interesting solution. Some may discount it right away, but I just might give it a try.DZVette said:I've had some luck using short pieces of the oversize pipe cleaners you get at craft shops. I take two pieces about an inch long, bend them in half and insert the two little V pieces at right angles to each other into the hole. The fuzz tends to hold them in place and I think the twisted wire maybe gives the screw a little more bite. Worth a shot.
DZ
