The opti spark is the 'distributor' on the LT1/4 engines. It sits perpendicular to the engine front cover. It resides below the water pump and is driven off of the cam shaft. It is a bear to change and is usually changed during the installation of a new water pump that usually happens around 50 to 70k miles.
