D
DMGroh
I'm installing a new opti in a 96 LT1 (stock) and have some questions that are not addressed in Helm's.
1. Water Pump gaskets - go on dry or use permatex?
2. Water Pump Bolts - do they penetrate into water passages where
I need silicone or some other sealer?
3. Where the opti "gear" (part that fits over the dowel pin) goes thru the timing cover, I'm not sure if there is a seal there. Shouldn't the metal opti part that sets inside the timing cover be lubricated with some sort of grease? If there is a $2 seal in there, now is the time to replace it.
4. Routing the new spark plug wires, especially on the drivers side. What is the easiest way? I have the tensioner pulley out, but it still looks formidable. Removing the inner fender skirts looks like it would help. I'd prefer not to mess with that whole Alternator/AC/Power Steering assembly.
5. What have I missed? I like wrenching on it, but this is getting tedious, and I don't want to go in there again anytime soon (although I totally cleaned and lubed the damper so it will come off easier, if there is a next time).
