Antz81
Got my first vette a few weeks ago and started fixing it up. Once I replaced the lamp for the check engine light I noticed it was going on and off as I was driving.
after checking the codes (13, 23, 34) I began to have a look around.
34 is an easy one, the sensor most likely just needs to be connected to the carb again (not sure why this would have been left of.
when I began looking into the oxygen sensor problem I noticed something odd, I can find the plug for it on the wiring loom, but the sensor itself is MIA. From what I gather it should be on the exhaust pipe just below the header. The exhaust and headers have been changed, but not sure why the O2 sensor would have been left out. Any ideas on my best option from here???
should I just bridge the sensor out with a resistor so the ECM thinks it's ok, or am I better off getting a hoe drilled and tapped for it?
