6
69MnyPit
I have a 69 Stingray stripped down to the glass. I was told by a local paint shop that I should use an epoxy primer after any major bodywork is accomplished, but before the very minor work i.e. scratches and gouges. Then, to use a regular sandable primer for final, then the single stage color. (Daytona Yellow). I enquired about the oil that is soaked through the door panels from the PO attempts at lubing the door mechanisms. (Even after repeated washings and degreasings, it comes back after a day or so). Their advise was to rough it up, degrease, and put the epoxy on right away. Does that sound right? Also, is the "fiberglass impregnated" Bondo good to use? Thanks,
