Paint Matching - Stock Wheels
  • Thread starter Thread starter MacShee98
M
MacShee98
I'm having trouble locating GM touch-up paint for the stock painted alum wheels on the 2002. The parts dept. guy couldn't find the matching number. My assumption is that it's the same silver-metallic paint for MY 2000, 2001 as well.
If anyone can help, I'd really appreciated it. (Got a small stone chip in the front left that I'd like to fix ASAP.)
Thanks!
I have found Dupli-Color High Performance Wheel Coating to be a very good match for my 2000 painted wheels. I have only seen it in a spray can. I have sprayed just a small section, such as where a wheel weight was, and from a few feet away, the sprayed area was not apparent unless you knew to look. If you are a perfectionist, and know what you are doing, you can even blend, clear it, and rub it out like the pros.
Thanks for the tip. I'm guessing that I could spray it into a cup and dip the brush from there - the spot I need to fix is smaller than the diameter of a pencil eraser, so masking off everything for just that spot to spray would be a pain.
Not to mention multiple coats would be required - yup, the stone chip is deep.
Thanks again. I'll give it a try.
MacShee,
The factory wheels do not match the silver paint on the cars. It's a special color, and could be found by your dealer. They may make a touch up version of it. Hope you find it ok.
Joe
