TWINRAY
- Joined
- Jul 24, 2003
- Messages
- 451
- Location
- Long Island, NY
- Corvette
- '67 Goodwood Green Coupe, '69 Lemans Blue Roadster
The paint on the rear top D/S fender and on the cowling from the D/S fender to the middle of the window is pimpling on my "67.
History:
I stripped the paint off the car with "Wonder Paste". A product I used before when I stripped the paint off the '69. The stripping on the '67 was done in 1976. After that, and I did degrease with Prep Sol prior to the stripping and used fast dry Enamel Reducer to clean up prior to applying primer surfacer. The car was in a garaged (unused) in primer for 14 year 1989. The finish cost of Acrilic Lacquer was applied. I drove the car yearly (summer driving) yearly and all was OK until about 4 years ago. The pimpling started and formed pin head sized "zits." An oily film appeared also.
I scraped the rough surface and now I'm left with a bunch of pinholes. Questions are what caused this after 7 years of driving
History:
, and then block sanding.
Well ,the paint problems could be a number of things or it was just at the end of its life.Lacquer is the lowest quality of paint nowadays.It looks awsome when first done,it just doesnt hold up.Also ,Lacquer primer isnt waterproof like todays epoxy and urethane primers.If you wet sanded the primer it could have dampened the fiberglass beneath it but it would have to have been wet for a long time for that to happen.The other is that maybe the bare fiberglass wasnt completely dry before priming it.If I had to blame it on one thing I would say it has just came to the end of its life.
