zackm58941
Well I was home for the long weekend and decided to begin trouble shooting on why my passenger front parking lamp/turning signal is so bright. Here is the situation, when the lights are off, the turn signals get the same amount of power ( about .5 Volts) but as soon as either the parking lamps are turned on or the headlights are on the front passenger turn signal/parking lamp gets around 7 Volts. All other exterior lighting works fine, no other apparent problems except I still have that problem with the interior lights not wanting to go off... I checked all the wires from the front of the car to the firewall and they all are in good condition, none are worn or exposed that would cause a cross-short there. So now I'm just a bit stumped, I have a Chilton's manual with the wiring diagrams and another older Corvette book with WAY more detailed wiring diagrams that I have looked at but still not too sure what could be the cause. Could there be a problem with the headlight switch? Please let me know, I'd really appreciate any help!! Thanks!
