Perfect Sparkplug Wrench
  • Thread starter Thread starter MPoore
M
MPoore
I couldn't use a standard sparkplug wrench to tighten sparkplugs because of headers that could have been enginered better. I looked around the Internet and found this tool:
http://www.enjoythedrive.com/content/?ID=25266
Being cheap and in a hurry, I went to Sears and bought a Craftsman spakplug socket for $3.99. I removed the rubber insert, ground the square end so a spark plug could slide through, and cut 3/4" off the hex end. This tool is awesome. If you have a 3/4 ratcheting box wrench, it will fit on the socket and make sparkplug installation a snap.
If you want to try this, make sure you buy a socket that has the internal hex cast all the way up the socket. I noticed that some of my sockets only have the hex about an inch of the way, which will not work. My other tip is use a die grinder to round out the square drive hole. I tried a drill bit and I guess the metal in the socket was too hard because the drill bit is trash.
Mike
That's a great idea!
I'll take all the spark-plug tips and tricks I can get.
Thanks !:w
mp,
I had a Z28 with headers and I custom made a 3/4 socket to something looked like your link/that tool. Too bad I did not buy a patent to it.
I like the price of the modified tool. That's what I will do rather then spend the $20. Great idea...thanks for the info!
Mike
Next time you need to drilll very hard metal. Try a masonry bit. You will be amazed with what they will drill. Be sure to run the drill below 500 rpm.
Great Idea
I am a new (1984) Corvette owner and have not done plugs yet. I'll try this when I do. I work, and live during the week, in the Indy area and drive my car every week. Can't afford to have it if I don't use is as a daily driver. So far so good. Makes that drive alot more fun!!! See ya around..
David
Welcome NewGuy! Corvettes (usually) wave at each other while driving past.
You may not need a special wrench, if your car is stock. :w
