danc5
- Joined
- Jul 23, 2008
- Messages
- 34
- Location
- delray beach, fl
- Corvette
- 2002 Black coupe, Stroked LS3 530whp/560lb/ft
I spent several hous today trying to figure out this issue, hoping someone else had had same issue and will post fix...
Rear passenger side light will not come on when braking...drivers side and center mount do come on. Passenger side lights work under every other scenario ie running lights, blinkers, emergency flash, but will not come on under braking. Does anyone have a wiring diagram specifically for the 2002 C5 that they could email me? The diag I was going by was a 1998 manual and the colors do not match up. There appears to be factory splices changing colors before the rear wiring harness connects the the main harness. This problem happened after I had a z06 diff installed and an exhaust system, but I dont see and cuts or problem areas on the harness. Drivin' me nuts literally!;help
Thanks in advance for any help!!!
