I had a Tremac T56 6-speed that I really wanted to install but after laying it beside a 4-speed and making measurements, it was quickly obvious the T56 would not fit without significant modification. If it would fit without modifying the frame I may have considered it. To do it right I would have removed the body from the frame, removed the top half of the X member about 8" wide and boxed it back in. Then, cut the tunnel (hump) from the fiber glass and make a new one.
The T56 shifter is five or six inches back of the stock location and in the middle, not offset. The top of the transmission is straight, not tapered down like the 4-speed tail shaft housing so it will hit the inside of the tunnel.
I ended up trading the T56 for my Doug Nash 5-speed after comparing it to a 4-speed.
I have not actually set a Richmond Gear 5 or 6-speed next to a 4-speed but the dimensions on their drawings suggest to me the tranmission body is longer than the Doug Nash 5-speed. I think the rear mount is farther back and the shifter is farther back on the Richmond.
The Doug Nash 5-speed is a close fit. I don't think the Richmond 6-speed will fit without cutting and I think the Richmond 5-speed uses the same case as the 6-speed. Maybe I am wrong about that, I have not asked Richmond that specific question.
To install the Doug Nash, take off the fan, unbolt the front mount and move the engine forward as much as possible to provide room. It is tight but will fit. (Did I just repeat myself?
I don't have the numbers off the transmission at hand. I will have to jack the car up and get them. The shifter is a Hurst. It looks very similar to Hurst 4-speed shifters. It has the same number of levers but reverse is shift lever to the right and back; a function of the transmission.
Shift pattern:
1 3 5
2 4 R
So, in weasel worded answer to your question, yes, my Doug Nash 5-speed will fit your 62 without cutting anything. We just have to make sure you get the right Doug Nash.
The advantage of the 5-speed is it has a very low first gear so I can run a 3.08 rearend and first gear still feels like a 4.56 rear end with a close ratio 4-speed. Actually, If I could find a 2.73 rearend I would install it. Unfortunately 3.08 is the highest gear available for our cars.
Now, if is switched to a 9"......
You say you located a dealer with a street Doug Nash. Ask him to send you the measurements for the rear mount and shifter mount from the bellhousing surface. Those may not be an exact match for the 4-speed but should be very close, within 1/2 inch or so. Also, ask the dealer what the 1st gear ratio is. I have the 3.27 (some people call it a 3.26) 1st gear.
Verle
