- Thread starter
- #41
chevy6673
is there supose to be a pice inbetween the cable and distributor or just the cable with i wire sticking out ..there is alock on the spare tire did it come with car or after market my key does not work with it but there is a 8 inch rally ..hopefully i will have some books at the end of the week or so thanks for the helpI would be careful with the tach cable. It may be disconected because the shaft gears are worn. If you grease it up it should go into the distributor with no problem. If it does not go in easily don't force it the teeth should mesh together with little effort no matter . It may not work of the shaft gear is worn but you will be able to tell that as soon as you hook it up.
