D
devilfish
As I understand our engines is external balanced, with a zero balanced damper, and external balanced FW or FP , right? Now as I understand it the GM stock FW and the FP has the same offset balance from the factory, and you only have to use the tiny wieghts in order to fine tune it ( place them on the same locations as your old FW on the new one ). Im I right so far??
Does that men if I get a 383 stroker kit that is external balanced, I can just install that in my engine and use my stock dual mass FW cause the all late350 FW has the same offset ( without the tiny wieghts ofcourse )? Or must I use my FW and reblance it?
