Poly bushings in front sway bar
Toms007
Moderator
Southwest Kansas
2007 Atomic Orange Coupe
I was working on the Vette today and I decided to go ahead and change out the bushings on the front anti-sway bar, I've bought them a while back, just haven't taken the time to put them in. Took me about 4 hours, as the ones I put in (VB&P polyurethane) were quite different than the ones that came out (OE rubber). I had to deal with removing an aluminum sleeve out of the lower A-arm after I got the rubber bushing out. And the sleeve in the end of the bar itself has to stay but working the old rubber out of it was no easy task either. And that 30mm bar is heavy. But it's all done and that another job down.
I love my new lift!
Urethane
I'm not crazy about plastic vs rubber bushings. I prefer urethane on a component that doesn't take weight, like a sway bar. Anywhere else, they make the ride too rough............Too much shock/vibe thru the car.....
