Hello everyone,
Some of you may have heard me talk about this on-going problem with my car. I installed an MSD 6AL box, and after hooking everything I started to experience popping / backfiring between 2,800 - 3,200 RPMs.
I have checked the folowing so far:
replaced power valve
installed jet sizes for 4777-7 as stock configuration (this at 5,000' alt is relatively rich)
checked for vacume leaks
adjusted gaps from 0.045" to 0.055" (milage increased but popping remained)
replaced sparkplugs
check idle mixture (approximately 11 HgIn at idle)
checked and adjusted timing (went from 10 initial to 14 initial)
Changed fuel pump (re-installed new OEM type)
checked MSD box connections
Replaced ignition wires
cleaned mechanical weights and springs in distributor
reinstalled HEI module and car functioned fine with no popping, although milage suffered some [it even ran well without popping and the 0.055" sparkplug gap :confused ])
re-attached msd box and checked connections a third time
replaced ingnition wires again (Accel)
drilled holes in rotor cap to vent ionized air
checked MSD box connections (even cleaned tie point at rear frame for negative cables)
refreshed carb while installing a 700 cfm body
checked idle misture (approximately 9.5 HgIn)
After installing the 700 cfm DP and double backfire protection, I returned from test run today because it popped and backfired at 3,000 rpm. AT home I noticed slight wistle at idle and discovered power valve blown.
The car runs strong through 2,800 rpm. At freeway speeds it mantains 70 - 75, but ever so slight load will make it pop (slight grade, strong wind, acceleration).
I need to find out what the engine is doing at 2,800 rpm - 3,200 rpm in fuel pressure and in timing. There is a plastic filter in fuel tank that could be causing problems but I need to find out fuel pressure first before dropping tank. Trying to make no more than one change at a time, so it has consumed the better of 7 weekends so far.
I believe that Jack mentioned that the MSD requires to run rich but how rich and why? How do I check for fuel pressure while under load at 2,800 - 3,200 rpm? (I suspect that I need a long hose, but I am affraid of spills or worst fire while holding fuel pressure gauge in vehicle and going through the motions)...the best guess would be a dyno run???
JohnZ..can you think of any suggestions to resolve this issue?
replaced sparkplugs
