Ported Vs. Manifold Source: Vacuum Advance
  • Thread starter Thread starter photovette
P
photovette
This was very helpful to me, so I thought I'd post it here:
This was written by a former GM engineer as a response to a similar question on a Camaro board:
As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance. I have this as a Word document if anyone wants it sent to them - I've cut-and-pasted it here; it's long, but hopefully it's also informative.
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
Good information. I have always been a little confused about this subject. Thanks.
Randy:beer
I came on here to get info on vacume advance, I have the Harry High School distributer (MSD) this is great! one question though, can I add vacume advance onto my Distributer??
This is good info. I'm running ported now and I will switch to manifold. Is it better to be a little leaner or richer, stock 350.
I just thought the clip explained mechanical and vacuum advance very clearly--I think I really have a grasp on what's going on now. Here is what I noticed after I switched to a manifold source:
When I hooked the vacuum advance up to manifold vacuum, I had to cut the idle speed screw way down and reset the idle mixture.
The idle mixture was about 7 full turns open from closed, now it's at 3.
Before, while cruising at 70+, the coolant temp would creep up to about 200F (I have a 180F T-stat). Now it stays solid at 185F.
The idle is much much smoother and the temperature doesn't move from 180F even with the a/c on. Of course, it's cool out now, but since I've had the car almost 4 years now, I know what it's perimeters were like before in all weather conditions.
I had a small amount of pinging at part throttle operation, but since my Pertronix distributor came with adjustable vacuum advance, I was able to dial it in perfectly.
Overall, a very noticable improvement.
Thanks for posting this information. Most informative posting I have read in a long time.
Mike
ported to manifold
I think when I get home I'm going to change from ported to manifold vacuum as well.
I have noticed some "beefy" cars before that when at idle, would sort of surge rpms on a cyclic basis. I wonder if that is what he was describing with unstable idle from too stout of a cam with a vacuum advanced distributer.
Thanks for the post!
Glad to help folks understand timing and vacuum advance; I'm the retired GM/Chrysler engineer who wrote it :) .
I looked to see who wrote it--to give credit where credit is due--but there was no name listed where I copied it from. I'm careful about such things being a pro photographer--you should see where some of my images end up! Anyhow, it is a super article--please feel free to write another one on properly tuning a QuadraJet when you get a chance! Thanks!
no vacume advance
:beer came on here to get info on vacume advance, I have the Harry High School distributer (MSD) this is great! one question though, can I add vacume advance onto my Distributer??
MSD makes vacuum advance distributors too, but you'll need to check with them (call their Tech Line) to see if the distributor model you have will accept a vacuum advance unit.
For JohnZ, is it better to be a liitle leaner or richer...carb speaking...
It's difficult to get all three systems (idle, main metering, and WOT) right on the money for all driving conditions, but the original out-of-the-box specs are usually the best compromise - a lot of effort went into developing them. Read your plugs to judge where you are and where you want to go; the insulators should (ideally) be light tan in color. Lighter is lean, darker is rich.
Am I missing something? Changing from ported to manifold vacuum changes nothing at cruise, it just changes the idle timing. I don't see how it could affect the coolant temps at cruise.
Question Concerning Port Vacuum
First, great article on vacuum advance.
Second, the article mentioned the carb port can be below or above the throttle plates.
My question is, if the port vacuum is below the throttle plates does it provide the same vacuum charectoristics as if it were connected to manifold vacuum?
Question #2: How can one confirm if their carb port is above or below the throttle plates?
Thanks again for the article.
Roy
AND of course, upon reading THAT, it's totally understandable....all those bad experiences that lead to the exact same conclusions some years ago....
where was the internet when we NEEDED it???
GENE
I switched last weekend after reading this from ported to manifold and I'm sold!!! Redid the timing and idle screws...very happy...
Thanks for the tip!
Roy
1. If the orifice in the venturi for the vacuum port is below the throttle plates at idle, that port will see full manifold vacuum, just like the fitting behind the carb that feeds the power brakes, headlight vacuum system, etc.; if the orifice in the venturi is above the throttle plates at idle, it won't see any vacuum at all until the throttle begins to open (this condition is called "ported vacuum").
2. Connect a vacuum gauge to the nipple on the side of the carb base where the distributor vacuum line is connected; if it shows 14"-20" of vacuum at idle, it's getting full manifold vacuum. If it doesn't show any vacuum at idle but responds when you open the throttle, it's "ported vacuum".
vacuum advance
I was tuning my 65 gto 461 timing & the engine runs very strong with vacuum advance, every one told me to remove vacuum advance. While reading Corvette site I saw your thread on vac adv This was a god send to me. I joined. Please give any advice on tri-powers Thanks Lukas Deans
