Bolisk
Just removed my springs to find that my brand new positive stop (PC) valve seals were shreaded and causing smoke out the tail pipes. Long story short the top of the seals were shreaded away from the metal ring base. They look like they were cut when installed or via some other means.
I'm trying to determine how this happened. They look like they were cut when installed or via some other means. I figured it has to be one of the following:
1) Crap seals (just split when the engine started)
2) Install failure (install tool damaged them
3) Spring retainer bottoming out on them
Is it possible for the spring retainer to bottom out on them and cut them? How much clearance (between the top of the seal and the bottom of the retainer) should I have with stock hi-perf springs and retainers?
Also, can I use o-ring seals at the retainer if my new valves do not have the second lower groove for the o-rings?
-JR
-JR
