toobroketoretire
Banned
Changing Rear End Lube
My positraction plates began popping every now and then last summer and popped a few days ago when I was down in the valley. When I installed the 3.70's several years ago I put a tube of Sta-Lube friction modifier in it and that worked okay for the first several thousand miles. Then one day it began popping again so I added a second tube. That cured the popping for the next 50,000 to 60,000 miles but with it popping again I am wondering of the Sta-Lube wears out over time. I bought two tubes of it today and tomorrow I'll change the 85W140 oil and put the two tubes into it. As my rear end has a drain plug it'll only take me a few minute to replace the oil and friction modifier. When I replace the rear end oil I drain it into a coffee can and mark the FULL level with a sharpie felt pen. Then I dump it out and put the friction modifier in first THEN the new lube into the can until it reaches the same FULL level. Then I heat it to about 200 degrees on a hot plate then gravity-feed it into the rear end with a 1/2" hose about 4 feet long from over the top of my right rear tire. Works great as there's no spillage and the pre-measured amount is exactly right.
I'll take a couple of pictures of my drain plug tomorrow so you can see how I installed it. I'll post the pictures tomorrow.
