Power Brakes
  • Thread starter Thread starter sagnoff
S
sagnoff
Has anyone added a brake booster to a 67 to convert to power brakes? Is it worth the effort?
The (correct) boosters aren't cheap, and you'll need a new short line from the front outlet to the block on the frame, and either a new rear line (PITA) or some creative work with a flaring tool and a union to adapt/lengthen the existing rear line to reach the rear outlet on the moved-forward master cylinder. '67 Power and manual used the same master cylinder (casting #5455509), so you don't have to buy a new one.
You'll also need to remove the driver's side vent grille to attach the upper anchor plates for the two upper booster support bolts.
Flaring tool is a double flare tool specifly for brake work not a single flare Sears has one for around 30 dollars
And the union must be made for the double flare you canot use the compression ones you find in a hardware store!
Yup, double-flares (I use an Imperial-Eastman double-flaring tool - have one for 37* AN fittings and another set for 45* SAE inverted-flare brake fittings); unions are BRAKE fitting unions, not "plumbing" or "compression" unions.
I believe Cannons corvette has just came out with a repo correct '67 brake booster.
Tom
Do you think it's worth the trouble to put in the powerbrake?
My '67 has manual brakes, and they feel pretty stout after driving my other cars with power brakes, but after a few miles I adjust to it and have no problem. We're all spoiled from the low pedal effort from our modern "driver" cars with power brakes :D
Thanks John. My daily driver is an M5, so I guess I'm a little spoiled.
My dad is thinking of doing this conversion, how hard is it to mount the booster "corectly"? His car is a '65 and he was going to put a '67 style system on it to get the dual resevoir, so it would never look exactualy correct for his year. But make it look like a factory job, not "Bubba" installed.
Tom
The booster will bolt right up to the existing studs from the pedal support that stick through the dash; all he'll have to do is remove the driver's side wiper arm and vent grille, use the upper booster leg holes as a template, drill two holes, and install the upper bolts and nuts, and re-install the grille and wiper arm. Nobody will ever notice that you used loose nuts and washers inside the grille cavity instead of the factory riveted-in nut plates, especially if you paint them black.
John,
Thanks for all the info, I didn't think it looked like it could be to tough when I was looking through a '67 assembly manual.
Tom
