I had a different wiring diagram that left out the two wires going to the anti theft. I've checked all the wiring. When I hit the passenger switch, the power goes over to the drivers switch, but it doesn't make it through to the actuator wires unless the drivers switch is also pressed. I wonder if the anti theft system is interfering because I think I was having an issue with the Tan wire, but the continuity was good. My drivers side lock cylinder doesn't turn counter clockwise, and I think the anti theft is disabled, but I did see a tan and a black wire hooked up to the lock cylinder. If the anti theft system isn't working could that cause a problem with the power lock operation?
It seems to me that the anti theft must be the issue, because I've checked everything else; however, after fighting with it all weekend, I ended up taking it in to the dealer today. Hopefully I'll get it back tomorrow. I guess I should have been a little more patient and looked at it again today. (Shh... don't tell my wife that we might have figured it out.)
