Hi, I'm new to the form and would appreciate a little help. Have a 1988 Corvette Hatchback and was going to replace the bladder pump diaphragm in the drivers seat when when raising the seat to get better access underneath, I heard a loud click/snap sound and now the seat will not respond to any movement. I disconnected the lines that run from the motor to the transmission and find that the motors run fine, so I assume the transmission is in need of replacement. Has anyone done this and what should I lookout for in swapping out the transmission? The repair manual describes removing the right horizontal adjuster and left rack but there is a coil spring under tension that looks like it will fly off if that side, motor side, is separated.
