White75
- Joined
- Sep 21, 2007
- Messages
- 496
- Location
- Kingwood (Houston) TX
- Corvette
- '75 L48 Auto White, '78 L82 4-spd SA
my new 78 has a power steering leak and I wanted to check the fluid level (which was bone dry)
The problem is that I had to remove the Alternator and loosen the alternator bracket and power steering pump to tilt it far enough from under the alternator bracket to remove the cap to check.
I am assuming this is not a normal procedure as I really don't want to have to go through that process every time I need to check the fluid.
What is the proper way to allow access to the reservoir cap? Should I get a smaller (or larger belt) to tilt it away from the alternator bracket.
This is an all original L-82.
