LannyL81
- Joined
- Jul 20, 2002
- Messages
- 653
- Location
- Oro Valley, AZ USA
- Corvette
- 81 White/Cinnabar, 96 CE LT4 sil/blk
Putting my 81 engine back together, finishing it up and put the PS pump on..no problems until I put the belt on. And now the PS pump pulley is at a small angle to the crank pulleys, pointing a bit towards the block on the crank pulley side. Now I can change the distance the PS pulley is on the PS pump shaft, but I have yet to figure out what is bent, or whatever it is causing this. I know if I leave it the PS belt is going to last about an hour before it gets chewed up from the angle.
Any hints, suggestions,???? I am stumped.......
It is the same PS pump that I took off the engine, same brackets...everything the same. What do I need to do??
Thanks,
Lanny
Tucson, AZ
Thanks,
Lanny
Tucson, AZ
