Yep, the crank pulley is cast iron 3 belt pulley. Heavy sucker. The water pump pulley is a 3 belt pulley also. Send me a email thru the forum & I can send you some pictures. Just as a coincidence, I'm currently going thru the P/S system on my car, so all of this is fresh on my mind. The Corvette assembly manual is a good reference for converting a non-P/S car to P/S.
@ TimAT - Haven't look at a non-a/c big block car in a while, but on a P/S-A/C car, the water pump belt isn't a captured belt. It has a idler pulley that rides on the outside of the belt to adjust the belt tension. The Idler is bolted to the front of the block to the right of the P/S pump and below & to the left of the water pump. Often, the bearing in the idler goes bad and people convert them to a captured belt due to the cost of the idler.
I also have NAPA part numbers for the belts should you need them.
