E
Edj
It appears that the power window motor on the drivers side of my "76" is bad (dead shord across motor terminals). Everything I read says to remove the entire regulator with the motor attached and block the torsion spring before removing the motor. Problem is the window is down and I can't raise it to remove the glass. Any suggestions?
