replacing left 1996 window motor, need info
well, I get into the 1996 vette this A.M. (its parked in my garage)and the left window is down, as is the right side, I hit the right side switch and the window goes up, I hit the left side rocker switch NADA!ZIP!, I start checking fuses and then test the switch with a V.O.M. meter and the switch seems to be good, so off to the local chevy dealers parts dept, I go, cost of new switch is $150, motors $148, so since IVE tested the switch, Im reasonably sure its the motor, I buy that ONLY,mostly because Im reasonably sure its original and about due anyway,and now IM about to install it and while Ive done it on my 1985 vette Ive yet to do it on my 1996 and was wondering if theres any tricks, potential things IVE OVER LOOKED or info you guys might care to let me in on BEFORE I jump into this little project today...ANYONE???
BTW IF YOU CAN WAIT A WEEK, ECKLERS SELLS THOSE DOOR MOTORS FOR $80 EACH
BTW, the motor AND THE BRACKETs and ROLLERS in the window track assembly were worn past the point of use, I needed the complete assembly, cost from chevy $350,(I can,t see how they loose money charging those prices for $40 worth of parts you can,t find elseware) but it was really a better deal in that it was far easier to install as a complete unit vs replacing the motor...and yes Im well aware they are listed far cheaper elseware!, but you pay thru the nose when you want the parts NOW, and are not willing to wait.
yeah, at times I pay retail. just to get the damn thing over with,if it could wait , I could have knocked 40% off the price
BTW re-reading this I see I failed to post the part number...ITS GM# 22063225 for the assembly with the motor for my driver side assembly on the 1996 vette, and ID STRONGLY ADVISE you go that route vs the motor alone as its far less aggravation and well worth the differance in cost
