POWER WINDOWS 1974
johnrem46
new jersey
1974 Bright yellow t top
My power window just stopped working. Where can I find the power window rely and the 30 amp ckt breaker? Hopefully it is one of these or a ground wire.
Both windows stopped working? or only one? Only one -- check the window switch. Both -- could be the relay. If memory serves, the relay is under the console, but check the AIM for the correct location. There could also be a circuit breaker at fault which might be under the hood.
checked fuse?, also on my 76, the wiring plugs into the fuse panel, it could of been knocked loose!
74 the power windows are fed from the fuse block- IGN UNFUSED- and that wire runs to a circuit breaker that's mounted on the firewall just behind and inboard of the master cylinder. the other wire runs back into the car, under the console to the relay. It's mounted next to the seatbelt safety relay at the front of the console.
