Prepping and repairing fiberglass hood
Classicvette63
York,Pa.
!963 Red Split Window Coupe
I bought a used hood at Carlisle last weekend. I just about have all of the old flaking paint scraped off. Underneath the hood is a light tan/brown with areas that are a whitish color. There is a spot at the back edge where the hood is cracked clean through, maybe 2 inches long. My questions are:
How do I repair the crack?
There is a low spot on top of the stinger part, should I build it up?
I am assuming there is a lot of sanding in my future. What grit paper?
What type of primer or sealer? I will be using laquer paint w/o clear coat.
On the under side, the cross braces have been cut. How do I close of the open ends?
The underside has a rough woven pattern to it. I would like it look as perfect as possible. How do I address that?
Normally I wouldn't attempt something like this, but since this a spare hood, I'm going to do it. Thanks for the help, Classic
You have an aftermarket hood. The original were press molded and should be smooth on both sides. And, it sounds like someone modified it to look like a 67 since you mentioned a "stinger". Fixing it will take time and patience but it will never look stock.
Post a few pictures of the problems.
Don
The hood was originally a '64 that someone added a "stinger" scoop to. I want to keep it that way. Classic
