Problem with Alternator???
  • Thread starter Thread starter TooTall
T
TooTall
OK Just replaced alternator and put in new Optima Yellow Top still getting charging System Fault
Pulled codes and see these codes:
P1637 Generator L-Terminal Circuit
P1638 Generator F-Terminal Circuit
The system does not seem to be charging correctly.
DTC P1637 Generator L-Terminal Circuit
TifToGif
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610944&evc=sm&pubid=180&cellId=32186&mspsdsubkey=1227#ss1-610944">
Circuit Description
The L-terminal circuit from the generator is a discrete circuit (a discrete circuit has no splices and only one source and destination) into the PCM. The PCM applies ignition voltage to the generator L-terminal circuit. A small amount of current flows from this circuit through the generator windings to ground to create a magnetic field which starts the generator process. When the generator is at operating speed and producing voltage, a solid state switch for the L-terminal circuit in the generator opens and the PCM detects that the initial startup current flow has stopped.
The PCM expects to detect low voltage on the L-terminal circuit prior to the generator rotating at operating speed and conversely expects the circuit to be at ignition voltage potential when the generator is operational. When the PCM detects a fault (circuit shorted to ground, or circuit shorted to voltage), the Driver Information Center will display Charging System Fault.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610944&evc=sm&pubid=180&cellId=32186&mspsdsubkey=1227#ss2-610944">Conditions for Running the DTC
The ignition switch in the ON position or the engine is operating.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610944&evc=sm&pubid=180&cellId=32186&mspsdsubkey=1227#ss3-610944">Conditions for Setting the DTC
  • The PCM detects the L terminal as Active with the key ON and the engine not running or the PCM detects the L-terminal as Inactive with the engine running.
  • All conditions met for 6 seconds.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610944&evc=sm&pubid=180&cellId=32186&mspsdsubkey=1227#ss4-610944">Action Taken When the DTC Sets
  • The PCM stores the DTC information into memory when the diagnostic runs and fails.
  • The malfunction indicator lamp (MIL) will not illuminate.
  • The PCM records the operating conditions at the time the diagnostic fails. The PCM stores this information in the Failure Records.
  • A message is displayed on the Drivers Information Center.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610944&evc=sm&pubid=180&cellId=32186&mspsdsubkey=1227#ss1-182985">Conditions for Clearing the DTC
  • A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
  • A history DTC will clear after 40 consecutive warm-up cycles, if no failures are reported by this or any other non-emission related diagnostic.
  • Use a scan tool in order to clear the DTC.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610944&evc=sm&pubid=180&cellId=32186&mspsdsubkey=1227#ss5-610944">Diagnostic Aids
Important
  • Remove any debris from the PCM connector surfaces before servicing the PCM. Inspect the PCM connector gaskets when diagnosing/replacing the module. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM.
  • For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616-A . Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
  • DTCs P1637 and P1638 may set at the same time depending on the failure. Also, the L-terminal circuit can cause a DTC P1638 to set. This diagnostic table diagnoses both DTCs P1637 and P1638.
  • Use a scan tool in order to diagnosis the generator circuits. The scan tool should display Inactive for the L terminal and 10-40 percent for the F terminal when the ignition is ON. When the engine is operating, the display should indicate that the L terminal is Active and the F terminal is greater than 5 percent.
  • A generator fault, such as a shorted output diode, malfunctioning regulator, open or shorted rotor, or open sense lead or battery feed may cause a low battery charge. Refer to Charging System Test in Engine Electrical for further information and generator diagnosis.
  • For an intermittent condition, refer to Symptoms .
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610944&evc=sm&pubid=180&cellId=32186&mspsdsubkey=1227#ss6-610944">Test Description
The numbers below refer to the step numbers on the Diagnostic Table.
  1. <LI value=2>This step verifies the fault is current.
    <A name=TD04><LI value=4>Inspect the circuit for an open or a short to ground if the test lamp did not illuminate.
    <A name=TD05><LI value=5>If the scan tool displays Active, this indicates the circuit is open.
    <A name=TD06><LI value=6>This step tests the F terminal for being shorted to a voltage. With the ignition ON, the F terminal should display between 10-40 percent. If the F terminal displays greater than 40 percent, inspect the circuit for a short to voltage.
    <A name=TD07><LI value=7>When the engine is started the L terminal should be active.
    <A name=TD08><LI value=8>This step is testing the L terminal for an open. If the L terminal displays Active when the circuit is grounded, this indicates the circuit is open.
    <A name=TD10>
  2. This step is testing the F terminal circuit for an open or a short to ground. If the F terminal parameter goes to 99 percent the condition is within the generator.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610944&evc=sm&pubid=180&cellId=32186&mspsdsubkey=1227#tab7-610944">DTC P1637/P1638 Generator L & F Terminal
Step
Action
Values
Yes
No
1
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
Important
The following tests assumes that the generator belt is installed correctly and in good condition. The battery is adequately charged.
  1. <LI type=1>Install a scan tool. <LI type=1>Turn ON the ignition leaving the engine OFF.
  2. Monitor the DTC Information using a scan tool.
Did DTC P1637 and/or P1638 fail this ignition?
Go to Step 4
Go to Step 3
3
  1. <LI type=1>Start the engine.
Go to Step 4
Go to Diagnostic Aids
4
  1. <LI type=1>Turn OFF the engine. <LI type=1>Disconnect the generator 4-way electrical connector. <LI type=1>Turn ON the ignition with the engine OFF.
  2. Probe the generator sense circuit (terminal S on generator) with the test lamp J 34142-B connected to ground and then probe the generator battery feed circuit (mounted to rear of generator) with the test lamp J 34142-B connected to ground.
Does the test lamp illuminate for both circuits?
Go to Step 5
Go to Step 15
5
  1. <LI type=1>Turn OFF the ignition. <LI type=1>Reconnect the generator 4-way electrical connector. <LI type=1>Turn ON the ignition with the engine OFF.
  2. Monitor the L terminal parameter using a scan tool in the Engine 3 Data list.
Does the scan tool display L terminal as inactive?
Go to Step 6
Go to Step 8
6
Monitor the F terminal parameter with a scan tool in the Engine 3 Data list.
Is the F terminal percentage less than the specified value?
40%
Go to Step 7
Go to Step 13
7
  2. Monitor the L terminal parameter.
Go to Step 14
Go to Step 10
8
  1. <LI type=1>Turn OFF the engine. <LI type=1>Disconnect the generator 4-way electrical connector. <LI type=1>Jumper the L terminal at the Generator harness connector to battery ground.
  2. Monitor the Generator L terminal using a scan tool.
Go to Step 20
Go to Step 9
9
  1. <LI type=1>Turn OFF the ignition. <LI type=1>Disconnect the PCM connector C2 located on the opposite side of the manufacturer's logo. Refer to Powertrain Control Module (PCM) Replacement .
  2. Test the continuity of the L terminal circuit from the PCM harness connector to the generator harness connector with the DMM. Refer to Testing for Continuity in Wiring Systems.
Does the DMM indicate continuity within the specified range?
0-2ohms
Go to Step 18
Go to Step 15
10
  1. <LI type=1>Disconnect the generator 4-way electrical connector. <LI type=1>Probe the F terminal at the Generator harness connector with the test lamp J 34142-B connected to B+ .
  2. Monitor the Generator F terminal using a scan tool while probing the circuit with a test lamp J 34142-B to B+.
Did the Generator F terminal parameter change from 0 to 99 percent?
Go to Step 20
Go to Step 11
11
Test the continuity of the F terminal circuit from the generator harness connector to battery ground with the DMM. Refer to Testing for Continuity in Wiring Systems.
0-10ohms
Go to Step 16
Go to Step 12
12
  2. Test the continuity of the F terminal circuit from the PCM harness connector to the generator harness connector with the DMM. Refer to Testing for Continuity in Wiring Systems.
0-2ohms
Go to Step 18
Go to Step 15
13
  2. Monitor the Generator F terminal with a scan tool.
Is the F terminal percentage at the specified value?
0%
Go to Step 21
Go to Step 17
14
  2. Monitor the Generator L terminal with a scan tool.
Go to Step 16
Go to Step 21
15
Repair the open, high resistance, or grounded generator circuit. Refer to Wiring Repairs in Wiring Systems.
Is the action complete?
Go to Step 22
16
Repair the short to ground in the generator circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 22
17
Repair the short to voltage on the F terminal circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 22
18
  1. <LI type=1>Inspect for a poor connection at the PCM harness connector. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
  2. If you find a poor connection, repair the connection as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
Go to Step 22
Go to Step 19
19
Important
Program the replacement PCM.
Replace the PCM. Refer to Powertrain Control Module (PCM) Replacement .
Go to Step 22
20
  1. <LI type=1>Inspect for poor connections at the generator electrical connector. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
Did you find and correct the condition?
Go to Step 22
Go to Step 21
21
Replace the generator. Refer to Generator Replacement in Engine Electrical.
Go to Step 22
22
  1. <LI type=1>Select the Diagnostic Trouble Code (DTC) option and the Clear DTC Information option using the scan tool. <LI type=1>Start the engine and idle at the normal operating temperature. <LI type=1>Select the Diagnostic Trouble Code (DTC) option and the Specific DTC option, then enter the DTC number using the scan tool.
  2. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this diagnostic ran and passed?
Go to Step 23
Go to Step 2
23
Select the Capture Info option and the Review Info option using the scan tool.
Does the scan tool display any DTCs that you have not diagnosed?
Go to the applicable DTC table
System OK
:thumb
DTC P1638 Generator F-Terminal Circuit
TifToGif
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610945&evc=sm&pubid=180&cellId=32187&mspsdsubkey=1227#ss1-610945">
Circuit Description
The generator has an input to the PCM called the F Terminal to indicate the percentage of total capacity that the generator is producing. This signal is detected by the PCM as a duty cycle from the generator and displayed on the scan tool as a percentage. The PCM can monitor the generators output under all conditions to determine if it is functioning normally.
When there is low demand from the electrical system on the generator, a low duty cycle percentage will be displayed. As more accessory load is placed on the generator, the duty cycle output detected by the PCM will approach 100 percent. A normally functioning generating system will never reach 100 percent as indicated on the scan tool.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610945&evc=sm&pubid=180&cellId=32187&mspsdsubkey=1227#ss2-610945">Conditions for Running the DTC
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610945&evc=sm&pubid=180&cellId=32187&mspsdsubkey=1227#ss3-610945">Conditions for Setting the DTC
  • The F Terminal indicates a duty cycle not between 10 and 40 percent with the ignition ON and the engine OFF or the duty cycle is less than 5 percent with the engine running.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610945&evc=sm&pubid=180&cellId=32187&mspsdsubkey=1227#ss4-610945">Action Taken When the DTC Sets
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610945&evc=sm&pubid=180&cellId=32187&mspsdsubkey=1227#ss1-182985">Conditions for Clearing the DTC
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610945&evc=sm&pubid=180&cellId=32187&mspsdsubkey=1227#ss5-610945">Diagnostic Aids
Important
  • For an intermittent condition, refer to Symptoms in Wiring Systems.
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610945&evc=sm&pubid=180&cellId=32187&mspsdsubkey=1227#ss1-553787">Test Description
    <A name=TD10>
<A href="http://127.0.0.1:9001/servlets/BlobShtml?ShtmlFile=610945&evc=sm&pubid=180&cellId=32187&mspsdsubkey=1227#tab2-553787">DTC P1637/P1638 Generator L & F Terminal
Step
Action
Values
Yes
No
1
Go to Step 2
2
Important
  1. <LI type=1>Install a scan tool. <LI type=1>Turn ON the ignition with the engine OFF.
  2. Monitor the DTC Information with a scan tool.
Go to Step 4
Go to Step 3
3
Go to Step 4
4
  2. Probe the generator sense circuit (terminal S on generator) with the test lamp J 34142-B connected to ground and then probe the generator battery feed circuit (mounted to rear of generator) with the test lamp connected to ground.
Go to Step 5
Go to Diagnostic System Check - Engine Electrical in Engine Electrical
5
  2. Monitor the L terminal parameter with a scan tool in the Engine 3 Data list.
Go to Step 6
Go to Step 8
6
40%
Go to Step 7
Go to Step 13
7
Go to Step 14
Go to Step 10
8
Go to Step 20
Go to Step 9
9
  2. Test the continuity of the L terminal circuit from the PCM harness connector to the generator harness connector using the DMM. Refer to Testing for Continuity in Wiring Systems.
0-2ohms
Go to Step 18
Go to Step 15
10
Go to Step 20
Go to Step 11
11
0-10ohms
Go to Step 16
Go to Step 12
12
0-2ohms
Go to Step 18
Go to Step 15
13
0%
Go to Step 21
Go to Step 17
14
Go to Step 16
Go to Step 21
15
Repair the open/high resistance in the generator circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 22
16
Go to Step 22
17
Go to Step 22
18
Go to Step 22
Go to Step 19
19
Important
Go to Step 22
20
Go to Step 22
Go to Step 21
21
Go to Step 22
22
Go to Step 23
Go to Step 2
23
System OK
Document ID# 610945
2000 Chevrolet/Geo Corvette
:thumb
Huh??????
Sound like I am out of my depth here.
