Problem with CD player
  • Thread starter Thread starter VTHokieVette
V
VTHokieVette
I have a 2003 Coupe, with a CD changer, a single disk in the dash, and I have installed the window valet. Window valet is programmed to turn on the stereo when the windows come down. Sometimes when I hit the unlock button 3 times, the CD player changes the CD that I was playing. For example, I was listening to disk 5 in the changer, but bought a CD & stuck it in the single CD player in the dash to listen. When I unlocked the car next time, not only was it not playing the single disk in the dash, it was playing Disk 1 in the changer . I relocked the car & unlocked it again. Now it was back on disk 5. I have noticed this on several occasions, but not every time I unlocked the car. I am the only driver of the vehicle, so I know someone else hasn't changed which disk was playing. Anybody else experiencing a similar problem? If so, did you find a fix?
Dave
HI there,
Something within the window valet is breaking down the communications line between the 2 CD players, creating the condition.
Remove the window valet and you should be fine.
Allthebest, c4c5:hb
Sounds somewhat strange to me.
Might try reprogramming you keyless entry too.
Now if you hold down the panic button & hit the trunk release and your upstairs toilet flushes…. Time to call the X-files!!
