leeboy66
The brake light on my 1977 Corvette has been on since I bought it a few weeks ago. The guy I bought it from said that the brakes needed to be bled. They felt a bit spongy, but continued to work well, although I have only driven the car once since I purchased it. Before driving it for the only the second time yesterday, I checked the brake fluid levels and found that the rear reservoir was a bit low. I added fluid and went for a cruise. The brake light remained on, but the brakes felt ok. When I got home, brake fluid was leaking pretty badly from the rear reservoir. Why do you think this is happening? I seem to have created a leak by adding more fluid. Do you think I need to replace the cover and gasket on the master cylinder? Or do you think I have a bigger problem?
