- Moderator
 - #1
KANE
Moderator
- Joined
 - Mar 2, 2002
- Messages
 - 3,244
- Location
 - KY
- Corvette
 - Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
Well, I'm just a fuel pump shy from having all the parts on hand or on their way that I need for my EFI retrofit.
So, with that said, I've been removing the smog pump, carb, and other stuff from and to include the intake in order to get ready for the TPI.
This is the second TPI system I've put on a Vette. The first one was almost ten years ago. The only thing is... I don't remember the particular Delco number for the 255 gph fuel pump I used last time. I'm going to go with an external one because I hate dropping the tank (did that on the last TPI swap until I put one on the frame rail).
What a mess though. I'm going to need to vacuum the intake off before I remove it- lots of.... funk... that could get into lifter valley. Yes, I'll even pull the water pump too- it looks rough and needs paint. I also need to invest in a spray bottle and some cleaner. It is amazing what 27 year old OEM dirt looks like.
